spider water fitting
Old 04-25-18, 12:02 PM
O
Replaced friends barbed water line fitting, it was broke, with one I had in my garage. When tight, it`s 180* degrees from my water pump. Am I missing something, or do I need to rotate the spider assy. ? Tnx. Part is called water distribution adaptor.
Old 04-25-18, 01:06 PM
Received 3,987 Upvotes on 3,579 Posts
Welcome to the forums.
Spider water fitting on what ?
You posted in evaporative coolers.
Old 04-25-18, 01:12 PM
O
It`s on a 4500 cfm evap. cooler. The top fitting that carries water from the pump up to the spider assy., & to the pads.
Old 04-25-18, 01:15 PM
Usually that is a swivel fitting where it can be tightened in any position. Sometimes you can put teflon tape on a fitting and not tighten it fully so it points in the right direction.
Old 04-25-18, 01:26 PM
O
This one goes on by hand until the shoulder stops it, which is facing away from the pump. Right now I have the threads wrapped with Teflon tape, as you said, but doesn`t seem to me to be correct. But if that`s the only solution, we`ll live with it.
