Installing a Thermostat on a 110v Water Cooler
Old 05-16-18, 05:59 PM
L
Exclamation Installing a Thermostat on a 110v Water Cooler
Hi, i'm new on the site and I have a problem, i just bought a Wifi Thermostat (Honeywell TH9320WF500 Wi-Fi) and in my house I have this old controller (Low Vent - High Vent - Low Cool - High Cool - Pump) so i was researching this thermostat and i found out that it works with 24v, and my water cooler is 110v, so, how can I make it work? thank you
Old 05-16-18, 08:33 PM
Received 1,197 Votes on 1,107 Posts
Welcome to the forums Leo.
A little more info is needed. It is not a direct installation. As you've noticed the thermostat runs on 24vac while your cooler use 120vac switching. For every function you want to switch you will need a relay. This could get a little messy.
Would you really need a wifi stat on an evap cooler ?
If you are set on the install you'd need to find and post a wiring diagram of your cooler.
A make and model may help.
Pictures are also a big help..... How-to-insert-pictures
Old 05-17-18, 11:14 AM
L
Thanks, i will take some pictures but is a basic Pump, 2 speed motor and that's it , i just bought the 120-24 transformer, ill check on those relays.
Old 05-17-18, 11:22 AM
L
Wiring
This is the wiring diagram that i found, sorry for the angle hehe, it's so hot in here
Last edited by PJmax; 05-17-18 at 06:01 PM. Reason: added 2nd enlarged/labeled picture
Old 05-17-18, 06:07 PM
Looks like one switch for the pump and a two speed switch for the fan.
Is that correct ?
Basically you need a 24vac transformer and a 24vac relay to control the unit. You could use this before those switches to turn power on to both at the same time.
You're going to be dealing with 120vac wiring which means the relay will need to be enclosed in an electrical box. You could also use a fan center which is everything in one package.
This is a fan center. The transformer and the relay come as a package attached to a 4" square box. You just supply a 4" square electrical box.
Honeywell-R8285A1048-Fan-Control-Center
Old 05-17-18, 06:27 PM
L
Ok, I bought a 120 - 24v Transformer, then a 2 pole contactor and an octa relay, what else could I need? or can you help me out with a wiring diagram?, thanks.
Old 05-17-18, 07:33 PM
Are you switching the power to both switches ?
That would mean that both switches stay set where you wanted them and your relay supplies power to the entire unit.
I need to know what contactor and octa relay you have. Both may not be needed.
