Old Rotobelt Swamp Cooler
Old 06-30-18, 12:01 AM
T
I have an old rotobelt swamp cooler that I got from Sears years ago. I can not find any model or serial number on it anywhere, or the book that came with it when I purchased it. I have purchased new rotobelt pads in the past, but without the book to get the part number I can't look anything up. What I need is new rotobelt pads for my old swamp cooler so that I can make it work and cool the house again. If anybody knows if the rotobelt pads are still available and where I can purchase replacement pads I could really use some help.
Thank you.
Old 06-30-18, 07:11 AM
Received 1,316 Votes on 1,216 Posts
Welcome to the forums.
Sears/Kenmore used several different vendors. I'm not familiar with the style of belt they used but another member might be. If you can post a few pictures of your unit... it may jog someones memory.
How-to-insert-pictures
Old 07-01-18, 03:05 PM
That cooler was made for Sears by the essick/champion cooler corp.
Call essick and give them the dimensions of the cooler and they'll be able to help you out. Don't know how much longer parts will be around for those things and as much as I always liked them, it may be time to think about replacing it.
Old 07-01-18, 03:08 PM
Thanks Sammy..... good to see you still checking in.
Old 07-01-18, 03:25 PM
I haven't been in here in a while. Lol I'm still around
Old 07-04-18, 06:48 PM
T
Thank you. I did check with essick/champion and they said that the cooler (pads) rotobelts are no longer available. I was just hoping that somebody had heard of another vendor that was making them. No such luck I'm thinking.
Old 08-17-19, 05:15 PM
T
I made some!
My landlord has the exact same set up and we have the exact same problem! So I ordered a role of cut-to-fit blue foam cooler padding, and I sewed it together on the ends and made my own
Old 08-18-19, 03:08 PM
Very ingenious. Probably will work adequately for that purpose.
The true test is if you can get enough humidity into the air using that foam.
The stuff used for roto belts is a media and is very dense to hold a lot of water.
Old 08-20-19, 02:38 AM
T
Actually it works great. I considered that before I chose the blue pad type. It's rotates and stays wet anyways. There was enough on the roll for good set. 😊
Old 09-26-19, 03:43 AM
A
Hi, since I discovered the pads are discontinued I have been thinking of sewing some too but hadn’t found any info on anyone’s doing it until your post. I have an old kenmore and needed 6294. The blue pad you used was duracool? Did you have any issues with the thickness of the different pad? I’m scared of ruining the cooler using something other than the roto-belt it was designed to use. Any advice? I’m excited to see that it worked for you, I’d love any info you have, thanks so much,
Old 07-19-20, 08:22 PM
B
Same problem
I just posted a bit ago about the same issue. Has anyone made any headway on this?
Old 07-20-20, 08:38 PM
A
I kept checking eBay for the 6294 pad but only found the next size up, 6295 or EP60. I cut the larger one and sewed it to the dimensions of the 6294 instead of using the blue duracool pad.
Old 07-20-20, 09:31 PM
That was good thinking.
Old 08-21-20, 08:15 PM
K
Tia Owens, i just read your post about making your own roto-belt cooler pads. I have the same issue as the rest of you , I can't find the pads because they are no longer made. You are a genius to come up with your own solution. Would you please share with me exactly what the material is, where I can buy it and how you went about sewing them together.
Thanks for what ever help you can give me. Lee
Old 08-21-20, 08:23 PM
You don't want your email address in public on site like DIY. You'll get spammed by the bots.
Go up to the person you want to contact and click on the name. Select "send a private message to.....". You'll get a replay much faster that way leaving a private message.
