Hide Cable Behind Siding
Old 04-23-16, 12:58 PM
Hello All,
See below pic.
I try tucking this cable up but it keeps falling down. Is there a clip or something that I can use to keep it from being exposed?
Name:  2016-04-23 14_45_45-IMG_5984.JPG - Windows Photo Viewer.jpg
Old 04-23-16, 01:06 PM
Received 128 Upvotes on 113 Posts
Unlock the siding from the starter strip, tuck in the wire as high as you can and reinstall with one of these.
https://www.zoro.com/malco-siding-re...B&gclsrc=aw.ds
Any Lowe's or HD will have them.
Old 05-01-16, 07:22 AM
How would you hide this cable?
Old 05-01-16, 07:42 AM
If there's enough slack you would be better off running it in the J molding above that beauty strip and let gravity be your friend.
Old 05-01-16, 07:43 AM
Tolyn Ironhand's Avatar
Received 814 Upvotes on 685 Posts
There are lots of clips that use two sided tape in the electrical section of the hardware/big box store. You could even use some duct seal or silicone to hold it in place. Use some clothes pins to hold it in place until the silicone dries.
Old 05-01-16, 10:43 AM
ray2047's Avatar
Run it through the attic and fish it down through the wall to where it is needed.
Old 05-02-16, 06:07 AM
Clips with 2 sided tape . . I will be in HD today and will look.
Would you have an example of a product name off the top of your head?
Old 05-02-16, 07:23 AM
Handyone's Avatar
You might have to look in the hardware section rather than electrical.
Look for the 3m hooks and cable keeps, they have quite a few to choose from.
