Sillcock/hose bib cover
Hi, we remodeled our laundry room and the dryer vent was relocated. I decided to install a sill **** where the old dryer vent was. This worked out fine, but since I didn't get to cut a nice clean hole in the siding, there's a square cut out of the vinyl siding where the dryer vent used to be. So I need to cover that square hole but I can't seem to find anything online and I don't know really what to search for... does something like this exist? Thanks!
A plastic fixture mounting block should do the job and might color-match your siding. There are small ones for outside outlets, medium for lights and such, and jumbo for really big lights. Square or octagonal. The regular surface mount block should cover your hole.
If the box store sells vinyl siding, they will most likely have these. If not, check with a real lumber yard or a vinyl siding specialty store. I did find this one, but it will need to be purchased online and shipped to you. It has flanges that will extend behind your siding for secure fitment. Builders Edge 5.5 in. x 8.625 in. #001 White Wrap Around Mounting Block-130130003001 - The Home Depot
