Exterior Window Frame
This happened in a hail storm. What would be the best product
to use in filling? Hopefully blend in with window & color. Thanks
That's a tough break. Sorry for the pun...
Trimbonder is a white pvc epoxy that would work well, but it's a bit expensive for a small repair. I would probably put masking tape around the repair to keep it clean, then just pump it full of OSI Quad sealant, then tool it smooth with a knife. Smooth lightly with some paint thinner if needed.
Any caulking will work, sure not going to look and worst than having two different types of siding and trim deviding them like that.
No, really most caulk will age and discolor. OSI Quad is made for exterior exposure and will not fade nor will it shrink or discolor. You can even order it in specific colors for larger jobs.
