Removing paint from stone veneer
Old 02-24-17, 03:12 PM
N
Hi all,
I bought a home that had some paint run from the shutters to the stone veneer. It was vacant for a while so it's been on there for years as far as I know. Anyone know how to get this off? Thanks!
Size:  50.8 KBName:  paint1.jpg
Old 02-24-17, 03:17 PM
Received 333 Votes on 296 Posts
Welcome to the forums!
Denatured alcohol will dissolve dried latex paint, a stronger solvent would be needed for oil base. I'd suggest chipping/scraping off what you can first.
Old 02-24-17, 05:14 PM
Marq1's Avatar
Received 397 Votes on 371 Posts
Do you know paint type?
Latex, goof-off is enamel reducer can be purchased in larger containers for a lot less.
Oil base, will need laquer thinner.
Old 02-25-17, 04:19 AM
Both 'goof off' and 'oops' will work on latex paints and while you could buy a smaller container than the quart/gallon of denatured alcohol, same size containers - denatured alcohol is cheaper.
Old 02-27-17, 01:31 PM
N
I believe it is latex (it rubbed off slightly with vinegar) thanks for the tips guys!
