In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
Canít Find the Studs Behind Hardy Plank Siding
Old 03-23-17, 07:41 AM
B
I am having some difficulty trying to find studs behind Hardy Plank siding. I have tried a couple of different electronic stud finders but none seem to find the studs.
Any ideas how to solve this?
Thanks.
Old 03-23-17, 08:05 AM
W
Received 21 Votes on 20 Posts
Find Studs
Find studs from the inside and carefully measure from the outside allowing for wall thickness of adjacent wall.
Old 03-23-17, 09:03 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Try to find one close to a window inside. Measure it to a spot on window edge. Make sure if studs are 16 or 24 inch on center, Go outside and measure it out.
Old 03-31-17, 01:24 PM
B
Thanks Wirepuller38. Started by trying that but couldn't find them on the inside of the wall with plywood over them.
Any other ideas?
Old 03-31-17, 01:32 PM
Received 330 Votes on 293 Posts
You have plywood on the interior walls?
Old 03-31-17, 02:02 PM
W
Any chance the Hardy Plank is nailed on the studs? If so, find the nails and you have found the studs.
Old 03-31-17, 03:39 PM
XSleeper's Avatar
Received 715 Votes on 662 Posts
Wirepuller, most hardieplank is blind nailed... thus the problem with finding the studs.
Best bet is to look for the spot where 2 butt joints meet in the field. That should be directly over a stud.
Finding the stud inside and measuring to the daylight opening of a window, then transferring that measurement outside should have worked by now.
