Stucco repair advice please
Old 07-10-17, 12:12 PM
I have this damage on the corner of a column outside the garage...yes, it was hit by a car! Somebody tried repairing it with some unknown gunk as you can see. I'm thinking I need to chip all that off and then use something like Stucco Patch.
But the hole is a couple of inches deep so do I need to make up a wood form to hold that much material in there, or just mix it fairly dry so that it will adhere?
Sorry that the pics are turned around. I don't know how to fix that.
Old 07-10-17, 01:31 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
I'd tack a form on just to keep it from settling out and use multiple layers of latex stucco patch. I know some will say go ahead and buy and mix stucco, but the patch in a tub seems to have worked ok for me. Just can't fill it all at once or it will take forever to dry.
Old 07-10-17, 01:35 PM
Received 742 Upvotes on 648 Posts
I've never used the patch in a tub stuff. I'd stuff some screen wire or something in the hole and then patch it.
Old 07-11-17, 05:49 AM
Should I leave those screws in? Somebody obviously tried to use them as rebar.
Old 07-11-17, 09:49 AM
As long as the screws are below the finished surface they shouldn't hurt anything, might even help give the repair stucco more to grab onto.
