Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Exterior Paneling and All Exterior Sidings
Reload this Page >
Basement Rim-joist meets bottom plate of slab addition; how to weather proof?
Old 07-28-17, 10:45 PM
Hello,
I'm working my way around the house replacing the old Homasote with plywood sheathing before installing the new siding.
Where the section of the house with a basement meets the section on a slab, it looks like more could have been done to make the bottom plate more weather proof.
Here's picture of the section I'm talking about:
There is no foam or gasket under the bottom plate on the slab (right side of the picture). The 2x4 plate is a little soft on the surface, but the softness is not deep, so it is not rotted yet. I've been in the house for about 25 years and I know that the addition was not new when we moved in, so, all things considered, it's holding up pretty well. Before I close it up though, I want to do what I can to make the area as weather proof as possible.
On the slab side, I'm thinking of using pressure treated plywood at the very bottom; at least to the height of the rim-joist on the basement side.
Any suggestions would be appreciated.
Thanks in advance.
Old 07-29-17, 03:48 AM
XSleeper's Avatar
Received 848 Votes on 777 Posts
I would probably seal the plate with some PL. Then cover the sheathing and rim with a WRB that extends 1" over the foundation.
Old 07-29-17, 08:05 AM
Thanks @XSleeper.
This stuff?
Old 07-29-17, 08:09 AM
XSleeper's Avatar
Sure, that or PL200, PL375, PL400.
