Filling hole drilled by the tele co.
Old 09-07-17, 11:30 AM
A
Behind the end cap is a hole that leads a run of cat3 straight into one of the rooms. Although this hole has existed for many years, only recently has it been discovered by argentine ants. I plan to remove the cable and seal the hole entirely. Is caulk the proper compound to use? If so, what type works well for this application?
Old 09-07-17, 11:44 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Any type of exterior caulk or even some cement/mortar/stucco can be used to fill!
Old 09-07-17, 03:09 PM
Received 839 Upvotes on 736 Posts
I use caulk because it's quicker/easier than mortar/stucco.
