Stain-paint
Old 09-15-17, 08:25 AM
T
Received 1 Upvote on 1 Post
Stain-paint
My house, etc., are stained gray. However I have an old outbuilding out back that has some areas with old yellow paint. I'd like to transition it to the gray stain. I power-washed it and got about half off. I don't want to scrape it. It's just an old building that no one sees very much. I tried going over the paint with some semi-solid gray stain, hoping it would turn it gray. It didn't work very well. Is there something I could apply to the whole thing look generally gray by covering the yellow paint and acting like stain on the bare wood?
Old 09-15-17, 08:51 AM
Received 824 Upvotes on 722 Posts
A solid stain should cover it, it's similar to a thin paint.
Old 09-15-17, 11:25 AM
T
Thank you Marksr. I will get some and try it. Do you have an opinion as to whether water-based or oil is best?
Old 09-15-17, 01:01 PM
Received 1,262 Upvotes on 1,203 Posts
Consensus is the south tends to warrant latex due to oil based deteriorating in UV so the further north, the more oil based becomes reasonable. I use oil based stain on my deck.
Old 09-15-17, 01:53 PM
T
Thnx Quickshift. So if latex is more resistant to UV, and certainly easier to clean up after, why would a person want to use oil?
Old 09-15-17, 02:26 PM
Oil base coatings tend to seal better than latex. What type of coating is currently on the out bldg? Generally it's best to stick with the same type [latex or oil] of coating.
Old 09-15-17, 02:27 PM
I believe it's going to last longer.
Old 09-15-17, 02:51 PM
T
Afraid I don't know what's on there. It's an old building I bought and moved to my property.
Old 09-15-17, 02:54 PM
If you scrub a small section with denatured alcohol you should be able to figure it out. If all it does is clean that area - it's oil base, if the color comes off on your rag and you can tell that some paint has been removed - it's latex. Oops and goof off will also work. Latex paint generally adheres well to weathered chalk free oil base paint.
