Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Exterior Paneling and All Exterior Sidings
Reload this Page >
Interior stain under exterior clear finish. OK or not?
Old 11-07-17, 01:31 PM
Hello,
I'd like to use Minwax interior stain on my new oak threshold. I will be coating it with multiple coats of Epiphanes clear, marine, finish with UV protection.
Is the UV protection from the Epiphanes sufficient to protect the stain color?
Is there a better option?
Thanks in advance.
Old 11-07-17, 02:08 PM
Received 128 Upvotes on 113 Posts
If it was mine I'd be using Bristol finish instead.
Fast drying, self leveling, far more UV protection.
Bristol Finish | High Performance Wood Coatings
Old 11-07-17, 02:20 PM
Received 824 Upvotes on 722 Posts
it will be ok, exterior wood doors are normally stained with the same/similar stain before being coated with a spar varnish/poly. Normally the finish will deteriorate before the stain does.
Old 11-07-17, 03:04 PM
Thanks @joecaption. The Bristol product does look excellent. Now I wish I hadn't already purchased the Epifanes. Truthfully, now I wish I hadn't bought an oak threshold. I should have had it made from a darker wood that didn't need to be stained.
Thanks @marksr. What you said is what I was thinking. The folks at Minwax, however, say their interior stain should not be used for an exterior application--even if covered with a UV protecting clear coat.
Old 11-07-17, 03:09 PM
Unless I'm mistaken every wood door I've ever stained was done using an interior stain [minwax or similar] .... and I've stained 100s of exterior wood doors over the years.
