I used the wrong fastener for cedar shake siding...what now?
I need some advice on this "d'oh" moment (although partially Grip-Rite's fault!):
I recently built a small structure on my back deck that is attached to the house. I sided with cedar shakes to match the rest of my house, which were then painted to match the house. Structure is 2x4 construction, 1/2 OSB sheathing, 30# felt paper stapled down, then cedar shakes with an 8" reveal on each course. .
I purchased several boxes of 1-1/2 hot galvanized box nails, the correct fastener for the job. Unfortunately, the boxes were loaded with a different fastener, which must have happened at the Grip-Rite factory somehow. They were loaded with Silver 1-1/4 in. Floor Metal Screw Nails. I was stupid enough not to realize the difference when I started nailing the cedar shingles to the siding and didn't realize my mistake until after I had finished. Again, the boxes were sealed from the manufacturer but with the wrong nails inside the wrong box.
These are the nails I used by mistake (I had to search a while to figure what type of nail it was):
https://www.homedepot.com/p/M-D-Buil...1501/100166931
My question is, do I need to painstakingly re-nail the shakes with the correct nail? I'm sure these flooring nails will rust at some point, but does anybody know how long it will take for that to happen? I don't really think holding power is an issue but the corrosion worries me.
The project was 5 bundles of cedar shakes so it was quite a bit of work. Don't really want to re-nail if I don't absolutely have to.
Thoughts? Thank you.
And we were referring to the exposed fasteners... top row, or under windows. You obviously can't do anything about the blind nails, unless you want to cry over spilled milk, which I'm sure you already did when you found out.
