Stucco patch after elastomeric paint
Received 0 Votes
A couple of years ago we had the stucco on our house repaired and then it was painted
with elastomeric paint. Because of a problem with the roof one area got wet continually.
The roof problem has been fixed and now I'm trying to figure out how to repair the stucco.
The only thing I've come up with so far that might work is to put new stucco on keeping
it from overlapping the existing, and after that cures use an elastomeric filler and then
paint.
Any suggestions would be appreciated.
Thanks
Chuck
paint.
Thanks
Chuck
I'm not sure why you'd need an elastomeric filler. I'd scrape off any loose paint, repair the stucco and after it's cured - prime and repaint as needed using matching elastomeric paint for the top coat.
