Mdf use
Old 12-12-18, 05:18 AM
B
Mdf use
Can I use MDF board for my soffits?
Old 12-12-18, 05:20 AM
Received 359 Votes on 316 Posts
I've seen drywall used for soffits so the answer would be yes ...... but why?
Old 12-12-18, 05:23 AM
XSleeper's Avatar
Received 774 Votes on 715 Posts
Not a good idea... it's not an exterior product, and will swell if it ever gets wet.
Old 12-12-18, 08:30 AM
Received 82 Votes on 77 Posts
Why not use plywood instead?
Old 12-14-18, 09:02 PM
D
Yes you can but there are many better options. MDF and water do not mix, even when painted. MDF will brake off a corner if nailed too close. Nails in the field will pucker MDF.
Options, Hardie board. Ply wood. PVC. Vinyl. Aluminum.
Old 12-15-18, 07:52 AM
P
Received 744 Votes on 684 Posts
I would use plywood or a premium OSB like Advantech. MDF is simply too susceptible to damage from water.
