Siding to steel truss
Old 04-10-19, 03:09 PM
B
I have this pole barn i am going to enclose using horizontal girts outside the poles (also adding more poles). Since the roof framing has quite a bit of overhang I am trying to figure out how to attach the framing to the trusses, inline with outside girts to lay the siding over it. I can't seem to find any framing photos that have this overhang.
Thanks
Old 04-10-19, 03:36 PM
XSleeper's Avatar
Received 1,958 Upvotes on 1,755 Posts
You won't get many answers without photos of your trusses.
Old 04-10-19, 04:23 PM
P
Received 2,263 Upvotes on 2,016 Posts
Instructions for posting pictures are at the top of each forum section. They can also be found here.
Old 04-11-19, 07:22 AM
B
Sorry, apparently only I could see the photo because I linked a private photo. Here it is
Old 04-11-19, 08:52 AM
Received 869 Upvotes on 760 Posts
On the sides you'd just erect stud walls between the posts. On the ends I'd frame up a new wall in front of the truss.
Old 04-11-19, 09:50 AM
B
But does the frame get bolted to the truss somehow? or bracketed to the rafters?
Thanks
Old 04-11-19, 05:53 PM
XSleeper's Avatar
Not really sure if this is what you're asking, but I would probably put a piece of 2x6 blocking laying flat between your roof perlins, so that it's laying flat on top of the steel trusses. Secure the blocking to the perlins. Then attach your posts to that blocking. Nothing really needs to be fastened to the steel. I wouldn't go drilling holes in it.
Old 04-15-19, 05:38 AM
B
That makes sense, I appreciate it
