Installing Flag Holder On Siding
You can't mount to the aluminum siding because it's too thin with no strength.
You need longer screws that will go thru the aluminum and into the sheathing.
One problem is you don't know what you have for sheathing, it's strength or how far back it is.
I use 4" long #10 or #12 screws ............... screws for comparison
This size screw will grab solidly
Second problem.... there is a gap between the aluminum siding and the sheathing. When you tighten the screws you could pull the bracket right thru the siding or distort the aluminum badly. I use three spacers between the bracket and the sheathing that fit loosely in a hole thru the siding.
example of spacers
example of spacers
Last edited by PJmax; 10-11-22 at 11:23 AM. Reason: replaced siding with sheathing
You need a mounting block like the one pictured below but without the holes in the center. They come in sizes depending on your siding so they are close to flush. Measure your siding row, vertically, to determine the size you need. Attach the block with 4 screws (see pjmax post) near the corners, each with a small washer, then attach the flagpole.
Two more points. First, add some silicone sealant around the mounting block top, left and right sides but not the bottom. Second, cover the existing holes with the mounting block but to the side, so you're not driving into them.
