Fence top
Fence top
What is the best way to cut off the top of 4x4 fence post ? I also have a section of fence that will be sloped, what tool should I use to cut the tops off level with the beam? Should I cut them at an angle first at top then adjust height board by board but cutting bottom?
You can do it with two passes of a 7 1/4" circle saw, or a reciprocating saw. I always leave an inch or soproud of the top rail, whether it is angled or straight. It falls to personal preference, but I like all picket tops to be level, stair stepping them down a slope. Others may have better solutions, so hang in there
Posts
