Paint over Screws?
Old 08-29-16, 07:00 PM
F
Paint over Screws?
Hello. My contractor used drywall screws instead of exterior screws to hold up my pick fence. I am in process of replacing them one by one with exterior screws. My questions is:
After installing exterior screws, should I paint over the new screws? I'm not sure what best practice should be.
Thanks in advance.
Old 08-29-16, 07:08 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Yes, what's your other option... paint around them? No thanks. You don't usually want the screws to be obvious, so if the rest of the fence is already painted, or even if it isn't go ahead and paint them.
Old 08-30-16, 02:51 AM
Received 676 Votes on 598 Posts
I agree, what type of finish is on the fence?
btw - welcome to the forums!
Old 08-30-16, 05:20 AM
Received 125 Votes on 110 Posts
Hope your using ceramic coated or Stainless steel decking screws not just galv.
Old 08-30-16, 08:46 AM
F
I'm using tan colored ceramic coded exterior screws. The fence is currently painted grey... I just wasn't sure what the process was, if the screws need to be painted. Wouldn't that make it difficult if I ever need to remove the screws in the future? That was my only concern.
Thanks.
Old 08-30-16, 02:46 PM
The screws don't have to be painted but often it looks better if they are. No big deal if the head gets filled with paint - just take a bit and knock it in with a hammer, that will set the bit in and there shouldn't be any issues removing the screw.
