Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Fences, Posts, Railings and Gates
Reload this Page >
What type of glue do I use when insert a lag bolt into newel post?
Old 10-13-17, 05:34 PM
C
I want to insert 1/2" into a newel post. I want it to be permanent. What type of adhesive should I use to make sure the lag bolt will not come off?
Old 10-13-17, 05:46 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Something is not making sense to me. Lag bolt is a giant screw. If the hole is drilled the right size, it won't just loosen and fall out. Seasonal changes in the wood, if outside, may loosen it somewhat, no matter what you inject. An epoxy (just about any type) would be the best choice, but the bolt may still loosen.
That's why deck framing uses through holes and bolts, nuts and washers. Much less chance of loosening.
Old 10-14-17, 07:45 AM
C
I see. This is for inside use. The thing is, I need the handrail guard to be removable in case I need to move furniture int/out of this room. Therefore, I need the newel post to be easily removable.
Old 10-14-17, 10:02 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
You won't want glue that makes for a permanent part.
