Privacy fence idea
Old 07-11-18, 10:07 PM
Privacy fence idea
Has anyone ever beveled fence pickets so they slide under each other to avoid gaps in a privacy fence? Shiplap would be the other idea, but the material usually sold for pickets is kind of thin for that. Thanks,
Neil
Old 07-12-18, 05:17 AM
Received 824 Upvotes on 722 Posts
I wouldn't do it. Overlapping them like that will cause those joints to take longer to dry [eventual rot] along with stopping any air flow which could be a problem if the wind picks up.
Old 07-12-18, 05:48 AM
P
Received 2,121 Upvotes on 1,899 Posts
I think the thin edge where you bevel is prone to crack, curl and break off. If you're that concerned about cracks in a solid fence you might consider something like this where the boards overlap.
