Vinyl privacy fence 45 turn
Received 0 Votes
I am hanging a vinyl privacy fence around my lot and on the corner I need to make a 45 degree turn. I wish to know if anyone has any clue as to how to attach the panels to the end posts on the corner I cannot find any brackets for 45 degree angles online my fence is a Belmont vinyl privacy fence and it is tan thanks for any input anyone has
To my knowledge they don't make 45 degree brackets for that type/brand of fencing. You would need to put in a second post... and place the post on a 45.
The only alternative that would allow you to use 1 post at the corner would be to make your own 45 degree shim... mount it to the post, then mount your bracket on that.
I've never installed a vinyl fence but when I've had to make an angle like that with wood fencing I've cut down a 2x4 at the desired angle and nailed or screwed it to the 4x4 to make the turn.
