How do I Keep my new Dog-Ear fence looking new?
Just put up a new dog-eared privacy fence, What do I use to treat it to keep it looking new? Others I've seen always turn gray after a year.
Cedar and other woods will naturally gray due to UV light. There is no permanent solution to this, as every product you think of using will require maintenance/ reapplication. If you want the fence to remain natural colored, simply apply a product like Thompsons waterseal as needed (every few months). However eventually the fence will need power washing and brightening with a wood bleach. Sealing the wood with a spar varnish or polyurethane is also not a permanent answer, and creates new maintenence problems of it's own.
Others elect to use a semi transparent or solid color stain on their fence since it will give you the most maintenance free longevity.
Most people however simply accept the fact that cedar fences turn gray and they don't fight it, just giving it a power washing as they see fit.
TWS won't prevent the wood from turning grey although it might slow it down some. TWS can make it difficult for other stains to successfully be applied over it.
You might like a translucent or toner stain. It's mostly clear with a little bit of color. They don't normally weather as long as a semi-transparent which doesn't last as long as a solid stain.
