Lift master CSW-24V swing gates
Hi new here I’m having a real problem finding some desperately needed motor brushes for a liftmaster K76-36398 motor. Did not what to spend $500.00 for new motor just for bad brushes. Any one have any idea where to find some? Thanks Rick
Welcome to the forums.
What series motor ?
MA-003B brushes (series B motor)
MA-003C brushes (series C motor)
MA-003E brushes (series E motor)
Liftmaster brushes will run around $40-50 a set.
Aftermarket run around $15-20.
What series motor ?
Thank you for your reply I’ll have to check on my motor series did not know there were three different ones. Any idea where to find aftermarket brushes I’ve looked all over the net.
Pjmax thanks again for your reply. Just a little background I am a volunteer for my HOA in Florida 40 years repairing elevators for Otis, volunteered to help maintain our five sets of swing gates models CSW-24V so I’m dealing with 10 motors on just the gates along with 5 liftmaster bar operators. Everything ties into two Dooking systems along with 20 cameras on two different recorders. Been doing it for about 5 years now get most of my parts from Gatehouse supply but they can’t help me with the brushes they only sell the motors. Thanks again. Rick
Hi there! I am having the same issue finding the correct replacement brushes for a k76-36398 motor in a Liftmaster CSL24V gate opener. Apparently, there was a service bulletin issued for a problem with incorrectly sized brushes. I attempted to upload the Service Bulletin but was unable. I have embedded a link to S2014-03. I have contacted Liftmaster about it, but they said since it was from 2014, that I am pretty much out of luck. They would not even give me the correct dimensions of the brushes. I am not sure what series my motor is an I was hoping someone could help me identify it. I've attached pictures of the brush and motor. Thanks in advance for any input that might help me get a little farther down the road with this issue.
Derrick
Derrick
Sorry for the delay.
There are many brush suppliers.
Do you have a dial micrometer ?
Measure the brushes for me.
We have determined the root cause to be a motor brush assembly that was sized slightly larger than the
specification tolerances.
That tells us absolutely nothing.
Do the brushes stick in the housings ?
Possibly the brushes are too big and overlapping the commutator too much.
