Fence caps, for decoration or protection?
Old 02-22-23, 11:21 PM
P
I have an old cedar picket fence. The section without caps has the picket tops deteriorating. The section with caps shows no such deterioration. Caps seem to prolong fence life. But a fence contractor says caps are for decoration. Is he correct?
Old 02-23-23, 01:21 AM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
Your referring to those copper capps for the 4x4 posts?
Mostly decorative, the top of the post is not the area that causes issues when it rots, what is in/at ground is most important, they look nice, especially when new but dont stay that way for long.
Norm201 voted this post useful.
Old 02-23-23, 02:38 AM
Received 753 Upvotes on 658 Posts
If the boards are straight cut at the top water can be slower getting removed and the caps could help. If the top of each board is cut at a slight angle it will help it shed water. Water soaking into the end grain is what will shorten the board's life.
Old 02-23-23, 04:54 AM
P
Received 1,840 Upvotes on 1,647 Posts
Caps can be both for decoration and protection. A cap protects the wood by acting like a little roof to keep water off the end grain. Some can be plain and functional while others can be ornate and decorative.
Old 02-23-23, 05:37 AM
N
Received 5 Upvotes on 5 Posts
He is wrong. Water sits on top of the posts. Destroying them eventually. When i mounted a 2x4 pressure treated wood to brick wall, i cut the top on a 45 degree angle so water doesn't sit on top of the wood. That's the correct way of doing it.
Old 02-23-23, 10:19 AM
P
Thank you for confirming that caps have functional value and not purely decorative.
I am not sure if I used the right word. I mean the 2x6 board sitting on top of the fence (not fence posts), above the top 2x4 rail. Fence posts are galvanized steel pipes embedded in concrete.
