Fireplace Gas Valve Problem
Old 11-15-18, 10:02 PM
A
Question Fireplace Gas Valve Problem
Our house was built in the 1970s (we’ve lived in it for 2 years now) and we recently had the chimney cleaned and a gas log system installed. The chimney/fireplace serviceman said the gas valve had a unique key (one that he had only seen one or two times). After he installed the gas log system he turned the gas valve on using a flathead screwdriver since he said the key is rare/hard to find. However, I feel like over time, using a flat head screwdriver will strip this piece of metal and make it unsafe to turn on/off. My husband and I tried to turn on the gas valve tonight and it is EXTEMELY hard to turn with a screwdriver. So I feel like something isn’t right. Does anyone know where I can find this type of key? Or was the chimney guy incorrect and this is just part of the valve that needs other pieces/adaptors? Also the floor plate to me looks weird because it has a circular hole. All the ones I’ve seen online have a square hole. I also find it strange that every single fireplace gas valve key I’ve seen online is the same. Why is my house different?
Old 11-16-18, 05:41 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
I've only ever heard of one company making those gas shut off valves and it is Dante.
Dante products
Old 11-20-18, 07:24 AM
Received 14 Upvotes on 11 Posts
You could try a 12 point (standard) socket set. An 8 point socket may work even better but they are harder to find.
Old 11-21-18, 11:21 AM
Received 132 Upvotes on 124 Posts
https://www.fireplacedoorsonline.com...alve-keys.html
https://www.supplyhouse.com/sh/contr...20valve%20keys
This is another sight or just google gas valve keys for fireplaces and you will see all your options,
Old 11-21-18, 12:15 PM
Thanks Spott..... different site but look like all Dante keys.
Old 11-21-18, 02:27 PM
Pete,
Just some options. Those were Dante's but on supply.com was another brand and even Amazon had different ones. Just in case he was looking for options. They're actually all over the place.
