Manometer gauge fluid setup
Old 12-14-18, 10:53 AM
P
I have a Dwyer 400-5-GAUGE. What is the best way to remove and replace the fluid? Which port should be used?
tks,
pa
can I cross post this? My question is about chimney manometer gage, so maybe "Fireplaces, Wood Burning and Heating Stoves, Flues and Chimneys" would be better.
Old 12-14-18, 11:26 AM
Received 4,051 Upvotes on 3,634 Posts
Thread moved to the fireplace forum.
Don't see much info on fluid replacement listed. It looks like the fluid would be drained from the bottom plug...... Dwyer series 400 manometer
Old 12-16-18, 04:14 AM
Received 14 Upvotes on 11 Posts
Why would you want to replace the fluid, it never goes bad. I had mine in my Dwyer draft gauge for 35 years and only had to add some if it tipped over or I used it at a pressure above or below its range.
Old 12-16-18, 04:48 AM
P
Bought used and Dwyer says replace occasionally to retain accuracy.
Old 12-16-18, 04:53 AM
P
Bottom knob is to adj zero. I'm guessing that I adj that about 1/2 way before I fill, but...I dont know...
