Country Comfort CC300 Gas?
Old 11-03-19, 09:45 PM
T
I purchased a home that i believe has a Country Comfort CC300. I was wondering if there is any reason this would have a gas line running to it? There is a “key hole” which I associate with gas inserts and I went under house and it looks like a gas line the goes into the chimney. could this be from a previous gas insert or would the CC300 use this gas for anything?
Old 11-04-19, 04:41 AM
P
Received 1,776 Upvotes on 1,588 Posts
I'll state the obvious. Look at it and see what it's using the gas for. Many fireplaces are plumbed with a gas line and valve during construction. Sometimes it's used for a fire starter or gas logs but it's possible it's not being used.
Old 11-04-19, 05:16 PM
Received 3,424 Upvotes on 3,070 Posts
As far as the manual....... no need for gas in that wood burning stove.
Country Comfort cc300 manual
Old 11-11-19, 09:17 AM
T
Thanks for comments and help. Pulled out CC300 insert and the gas line was capped underneath. Must have been used previously with gas insert or as a starter for wood.
