Portable electric fireplace: no heat
Old 03-22-24, 09:08 AM
F
I have a portable fireplace heater that I love, but it does not love me anymore. The flame works, the fan works but not the heater. It is made by a company called "Quality Craft" QC555, 1500 watts. The thermostat seems to be ok but I am not sure if it ok. Can anyone shed some light?
Old 03-22-24, 09:22 AM
P
Received 2,327 Upvotes on 2,069 Posts
Do you have a multimeter? Have you opened the heater up to look for the problem? Is it a burned out heating element? Is it a over temp safety switch that has tripped or blown?
Old 03-22-24, 09:46 AM
Received 4,155 Upvotes on 3,731 Posts
I can't find any info on that exact model.
As Dane mentioned a meter will be needed and most likely the problem with be a heat safety sensor.
Some are self resetting and some trip open and need replacement.
We can work with you but pictures would be needed of the inside wiring.
How to insert pictures.
Old 03-22-24, 02:43 PM
B
Received 322 Upvotes on 284 Posts
Help me understand your statement. "The flame works, the fan works but not the heater."
Old 03-22-24, 06:09 PM
It's an electric fireplace. It has a Mylar film "flame" tube that turns with a light shining thru.
It's basically a 1500 watt electric heater with the "real flame" look,.
