After cleaning tile how long to wait to apply sealer??
Instruction s don't specify, I'm using sealers choice gold on travertine tile... I just wanted to mop up the floor first, but is there a drying time needed?? The floor had been sealed once but only one coat was used.. So that's why I wanted to add another coat
If it is dry, you can apply sealer. The time specification is for a full 72 cure of NEW grout. Existing grout just needs to be dry unless excessive moisture is soaked into the grout then give it a day.
