Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Removing tile floor and cement board from subfloor
Old 02-18-17, 11:35 AM
B
I am demo'ing my bathroom. I have tile / some type of cement board and then wooden sub floor.
Can I pry the tile and cement board off the wooden subfloor with a crow bar?
How do i remove the thinset from the wooden subfloor? And specific tools needed?
Thanks!
Old 02-18-17, 11:42 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I usually use either an SDS chisel or a slammer bar.
Name:  floor scraper.jpg
Old 02-18-17, 12:11 PM
B
Will the sds chisel connected to a hammer drill chip up the wooden subfloor? I've read getting that thinset off is a pain in the a$$,
Old 02-18-17, 12:54 PM
chandler's Avatar
IF you dig too deep, it sure will. If you keep it at an angle it should remove it in good order. I just ordered a couple of wide blades for mine. We had to remove thinset from a concrete floor prior to laying flooring.
Old 02-18-17, 01:29 PM
B
you think attaching a scraper attachment to a sawzall would work?
