Question about supporting header over pocket door under load bearing wall
I want to install a 36" pocket door in a 12ft load bearing wall. The pocket door kit calls for a RO of 84.5"H X 74.5"W. The plan is to use 2-inch-by-8-inch headers compressing a 1/2-inch flitch plate, installed underneath the existing double top plate of the load bearing wall. Can I use single king and jack studs on each end of the header, or should I double up one/both at each end?
Depends on what your code requires in your area. If you follow r.502.5 (1) you want 2 per side and your header would be 80 1/2" long.
