Framing in plaster wall?
Old 10-10-17, 11:01 PM
Q
I'm moving into a place where the walls are plaster, the kind with wood panels close together and plaster on top. Do these walls have framing like drywall or not? I'm wondering how to fish electrical wire through with no frame to drill holes.
Old 10-11-17, 12:17 AM
ray2047's Avatar
Stud > lath > plaster = stud space on interior walls. A true brick house may not have studs on exterior walls so no space. A wood frame house will on exterior walls. Just use a 3/16" masonry drill to make holes in an inconspicuous place then insert a stiff wire to see how deep and if it will wiggle around.
Old 10-11-17, 04:38 AM
The lath is nailed to studs but back then they didn't worry too much about equal spacing. If the studs are on 16" centers, there may be some that vary and inch or so.
