Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Floating basement Wall murphy bed installation question
Old 12-31-17, 02:36 PM
My basement walls are hung from the ceiling (Colorado requirement).
I want to install a murphy bed which sets on the floor but is screwed to the wall with 6 large screws.
Any ideas how to do this so those 6 large screws can slide up and down when the floor moves up and down?
THANKS!
Old 12-31-17, 02:39 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
Sounds like you would need to use t-track and t-bolts instead of screws... t-track is screwed to the wall framing vertically... then bolt to it with the t-bolts... loose enough for it to move up and down a little.
Old 12-31-17, 03:12 PM
Thank you so much! That looks like it will work perfect!
