Uneven floor
Old 03-28-18, 04:59 PM
W
Uneven floor
I am wanting to put down hardwood flooring and have a slight problem. The carport was inclosed and made into dining room and dining room and living room is one big room.Where the floop of dining room and lIvins room meet is maybe inch or so unlevel.The highest point beine all the way across floor.What can I do to level this out.Thanks for your help
Old 03-29-18, 08:04 AM
Received 1,279 Upvotes on 1,217 Posts
First question would be why it's not level as that can influence what one would do about it.
Old 03-29-18, 09:09 AM
P
Received 2,261 Upvotes on 2,014 Posts
Is it an even drop from one room to the next or is the floor sloped?
Old 03-29-18, 12:33 PM
W
Uneven floor
The floor is slightly slopped. This happen when new floor was put in joining old floor to living room.Not terrible but could cause problem putting down hardwood flooring. I have carpet down now.
Old 03-29-18, 12:55 PM
P
What type of wood flooring are you going to put down? It makes a difference if it's solid 3/4" tongue and groove or a thinner click lock floating floor.
Old 03-29-18, 05:37 PM
czizzi's Avatar
In the carport, did they build up the flooring height to match the existing house? As previously mentioned, is the floor sloped on a steady plane, or does it dip in the middle of the room?
Old 03-29-18, 07:16 PM
W
The floor was built up to match existing for in living room.It does have a slight slope where the 2 rooms meet.Other than where the 2 rooms meet everything is level.I would be putting down the lock type flooring.Thanks
Old 03-29-18, 07:24 PM
czizzi's Avatar
Just use a "T" molding between the two floors which will allow for a transition from one floor profile to the next.
