Protecting floor joists resting on cement?
Old 07-10-18, 08:03 PM
D
I have to put floor joists over cement to make it level and the same height as the adjacent floor. 2x3s with shims are the correct height and the easiest so I don't have to rip a lot of 2x4s. Here's the question:
Only a couple of feet of each joist rest on the cement. If I use doug fir 2x3 will Sill Seal protect the joists from decay? Should I put down a moisture barrier too?
I thought about using 2x4 PT but then i have to rip a bunch of them or I could (or get the local lumber yard to) rip down redwood 2x8s into 1/3rds. I prefer using 2x3 doug fir. Suggestions?
Old 07-11-18, 04:36 AM
P
Received 1,851 Upvotes on 1,657 Posts
I would use pressure treated lumber. If you can find it wood treated for ground contact would be best.
Yes, I would put down a moisture barrier. A strip of 6 mil plastic at the minimum.
Old 07-11-18, 09:04 AM
Marq1's Avatar
Received 1,142 Upvotes on 1,035 Posts
Indoor, outdoor, above or below grade?
