Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Sealing 2x4 when attaching to exterior brick wall?
Old 10-06-18, 10:34 AM
E
Was wondering the best way to seal a (PT) 2x4 against an exterior brick wall? At first I was thinking of just using the sill gasket pink foam, not I'm wondering if I should just use construction adhesive instead? I'm going to attach the stud to the brick with tapcons. It's non-load bearing if that matters.
Thanks
Old 10-06-18, 10:59 AM
Received 333 Votes on 296 Posts
Does it need to be sealed against the brick? what is the application?
Old 10-06-18, 11:15 AM
E
It's expanding an interior area of the house aka it's a new exterior wall. So I'd like to seal it for drafts/bugs/moisture, etc. The brick is the exterior of the house that extends inside as an exposed wall.
Old 10-06-18, 03:20 PM
XSleeper's Avatar
Received 723 Votes on 669 Posts
Yes, construction adhesive would be best.
