Framing corners
Old 12-14-18, 03:23 AM
C
Framing corners
I've seen lots of info about best way to frame inside corners. Is there a best or preferred way to frame outside corners? Both walls are exterior walls in the basement, (we have a "bump out" area)
Old 12-14-18, 03:42 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
California corners, no dead area and a surface to nail drywall.
https://www.doityourself.com/forum/a...1&d=1544787720
Old 12-14-18, 10:56 AM
C
So that is a pic of an inside corner, right not an outside corner
Old 12-14-18, 11:31 AM
Received 27 Upvotes on 21 Posts
You could go with one of the options in this video. It talks about interior corners, but should work for exterior as well: https://www.youtube.com/watch?v=BUsrnbCi7gU
Old 12-14-18, 12:58 PM
Marq1's Avatar
It's both but if you had a corner that did not need a inside nailing surface then you would just eliminate the extra stud!
https://www.doityourself.com/forum/a...1&d=1544821091
Old 12-17-18, 10:30 AM
C
Ok thanks. Wasnt sure if it needed extra strength
