Sunroom removing load bearing posts
Old 07-19-19, 06:33 AM
E
I'd like to remove one or two of these posts... They go from the floor to two joined 2x12 beams. There is an actual shingled roof above, so the roof is heavy. Any advice on how to approach the project? Should I just eliminate 2 posts? Should I eliminate all and replace them with something bigger than a 3x3? Any advice appreciated.
I've tried to reach out to contractors and nobody seems interested. Pictures should be attached for some reason I don't see them.
Old 07-19-19, 07:04 AM
XSleeper's Avatar
Received 722 Votes on 668 Posts
You can't remove any posts, they are there for a reason.
Old 07-19-19, 07:51 AM
P
Received 687 Votes on 634 Posts
Instructions for posting pictures are in a sticky at the top of every forum section.
Old 07-19-19, 11:15 AM
E
I imagine I can if the remaining posts provide sufficient support for the roof and/or I replace the 2x12 with a different material. Your post also assumes whomever did this knew what they were doing. Thanks, though.
