Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Side door stairs - can I trim plywood and not alter the stair structure?
Old 08-06-19, 09:50 PM
H
Received 1 Upvote on 1 Post
Our side entrance has a small 3 step down to the landing for the doorway. In the basement below, the stairs have a couple of plywood right angle pieces that jut out and are a nuisance and an eye sore.
Can I just cut the plywood along the red lines in the pics and not compromise the stair's structure and strength? I hope I'm making sense.
Old 08-06-19, 11:10 PM
Received 1,232 Upvotes on 1,180 Posts
Pics didn't make it with the post.
Old 08-06-19, 11:56 PM
H
Thanks, I think I have them attached now...
Old 08-07-19, 05:06 AM
P
Received 1,954 Upvotes on 1,750 Posts
Yes, those head banging corners can be trimmed off.
Old 08-07-19, 07:21 AM
H
Thanks for replying Pilot Dane - "head banging corners" is a good description of them... they are an eye sore too.
Can/should I trim the plywood completey flush with the angled stair side board or leave a couple of inches away like the red line shows in the pic?
Can/should I trim off some of the horizontal 2x6 side platform lumber (at an approx a 45 degree angle) as well as a couple inches of the double layer of sub flooring? It would give more head room and would finish it off nicely. Would this reduce the integrity/structural strength of the stair structure at all?
Old 08-15-19, 02:51 PM
H
Pilot Dane (or anyone else),
Have any input into my question?
Old 08-15-19, 04:17 PM
XSleeper's Avatar
Received 1,813 Upvotes on 1,630 Posts
Any wood below the skirt isn't doing anything. (Top picture, 1 1/2" above your red line on the left side.)
I have no idea what that wavy plywood is doing there either unless someone though it would be a good place for a shelf.
Old 08-15-19, 04:25 PM
Received 3,632 Upvotes on 3,254 Posts
By the way that plywood is set up..... it looks like that was a cabinet at one time and then taken apart.
The plywood is doing nothing for the integrity of the stairs.
Old 08-15-19, 04:48 PM
H
Thanks for the responses PJMax, Xsleeper and Pilot Dane. So what is supporting the stair platform in the both corners? It feels solid enough when one puts weight on the stairs...
Old 08-15-19, 08:51 PM
XSleeper's Avatar
A little hard to tell how it is built from 2 pictures, but it looks like the plywood is a landing (that extends out tge other side) and as long as you don't cut off any parts that are nailed to the sides of your structure, the extraneous parts that hang out and extend out the back are doing nothing but making it look goofy.
If you do cut off those lower triangles, and there is a fastener or two into those 2x6s, you just might want to add a couple more screws above your cut line to replace any fasteners that were cut off.
