floor from hell
Old 09-10-19, 12:34 AM
floor from hell
my brothers living room floor is buckling just bout center of the front part of house subfloor is good the interior floor is tongue and groove its making a peak almost any thoughts
Old 09-10-19, 02:42 AM
Received 316 Votes on 280 Posts
Welcome to the forums Jamie!
Is it just the hardwood that is buckling? can you check the subfloor and joists from underneath?
How old is the flooring? when did the buckling start?
If it's just the hardwood it's usually a moisture/humidity issue making the wood swell.
Old 09-11-19, 05:30 AM
N
Received 18 Votes on 16 Posts
Welcome to the forum.
Going to take Marksr questions a bit further.
What type of flooring is the floor covering?
If it's laminate and newer, it's likely it was installed too tight to the walls which resulted in the boards expanding and causing the lift.
Wood in general, was the area lifting exposed to water prior to it starting to lift? If it's near a window, you may have some water leaking.
Emiliana voted this post useful.
