non load bearing wall fasten to a sister board?
Old 08-07-23, 01:56 PM
In my basement I need to build a wall in parallel to a floor joist above. the wall is non load bearing, but lands between two joists. I found it is very close, and if I add a sister board next to the floor joist above, it will screw into that very nicely. Is this allowed, or do I need to install blocking every 16" on center between two floor joists? most times I wouldn't have a problem with it, but its an exterior wall, so in order to do that, I would need to remove some of the spray foam up there which I would rather not touch lol.
Old 08-07-23, 03:22 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
You also usually need drywall backing if you are hanging sheetrock on the ceiling, so you either want to lay a 2x6 flat on top of your top plate and fasten that to the joist, or put in perpendicular blocking every 16 - 24" or so.
Old 08-07-23, 03:32 PM
Thanks! My current plan is to take down the existing drywall, install the sister boards, then re-hang the drywall. Then fasten the top plate to the sister board. That way the drywall creates the fire blocking above the top plate. Hopefully that works?
Old 08-07-23, 03:43 PM
XSleeper's Avatar
It works if you don't have any electrical to do.
Old 08-07-23, 03:45 PM
Can you tell me more about the electrical? So if I need electric in the wall I canít put it below the drywall? Sorry for my confusion, this is new to me so I want to do it right.
Old 08-07-23, 06:11 PM
XSleeper's Avatar
The electrician will be pretty upset if you put up drywall before he roughs in the wiring.
Old 08-07-23, 06:29 PM
Lol yes, I could bet! I was thinking once the wall is fully framed I could use an ocelating tool to cut a nice straight edge along the front of the wall, then take Sheetrock back off the ceiling for hvac and electric.
