Leg facing in or out?
Old 02-16-16, 07:54 AM
D
Double three leg pedestal table......does the single long leg face in towards the center or out? Was told that the single leg should always face inwards to provide better support but....then those who sit at each end have to straddle that leg but, with the other two facing outward it does not look like allot of room to place your feet? So what is better?
Old 02-16-16, 08:22 AM
Received 1,197 Upvotes on 1,152 Posts
I can't envision this, can you post a picture or two?
Old 02-16-16, 08:25 AM
Received 753 Upvotes on 658 Posts
What is the size of the table? how many chairs?
Old 02-16-16, 08:35 AM
Old 02-16-16, 08:40 AM
Shadeladie's Avatar
Super Moderator
Received 347 Upvotes on 278 Posts
I don't think so. He mentions a single long leg. FWIW, I'm not picturing it's either.
Old 02-16-16, 08:59 AM
But he said "Double three leg pedestal table" so I would assume it is like the link that SS supplied. I guess David will verify later
G
Received 1 Upvote on 1 Post
I'm with stickshift:
vs
Doesn't look like either way would be much of an obstacle to chairs or feet.
Old 02-16-16, 09:02 AM
With the single leg pointed inward the corners of the table are more stable. Depending on the length of the table I'd expect it to set 6, 4 or each side and 1 on each end. I would think the leg would only be an issue if you tried to crowd more folks at the table than it was designed for.
Old 02-16-16, 09:11 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Old 02-16-16, 09:13 AM
Assuming I have the right table design, I think Tow Guy is right and the long leg goes inward.
Old 02-16-16, 11:35 AM
Handyone's Avatar
Stickshift and Tow Guy are right, the long leg goes inwards.
Do a search for Duncan Phyfe tables. This is some of the finest furniture ever made.
