Vintage metal bookcase question
Old 07-02-19, 09:03 AM
Hello...I'm in need of ID'ing and sourcing a couple dozen shelf pegs/brackets as shown in the attached image. Nothing readily available in hardware stores, or even what I've found online seem to work. Any ideas would be immensely appreciated!
Old 07-02-19, 09:18 AM
Received 680 Votes on 601 Posts
How wide are the shelves? how much weight is put on them?
You might take a strip of steel and bend it with pliers to make your own brackets.
Old 07-02-19, 09:26 AM
It's unfortunately meant to hold quite a few hard cover books, so it'll be heavy. Worth a shot though!
Old 07-02-19, 11:15 AM
If the original brackets held the weight, making new ones out of the same gauge steel should be ok. You just don't want to use thinner steel.
