What's recommended as moisture barrier ?
Old 01-04-18, 07:38 PM
P
Received 2 Upvotes on 2 Posts
I built a nice bathroom vanity, using 3/4 Grade A-2 plywood and spent a lot of time finishing the outside.... I really want to now just apply the simplest "solution" to protect the inside of the cabinet.... so wonder if I could just apply some sort of sealer / primer and that's it.
Don't really need to paint / stain as I find the current , inner finish acceptable ...just need to protect the material from the obvious high humidity of the bathroom.
what would you recommend ?
thank you
Old 01-04-18, 07:39 PM
XSleeper's Avatar
Received 1,910 Upvotes on 1,716 Posts
Lacquer.?...................................
Old 01-05-18, 03:50 AM
Received 835 Upvotes on 732 Posts
Poly will also work. ..........
