Go Back  DoItYourself.com Community Forums > Hardware, Tools, Wood & Metal Working, Home & Business Security > Furniture, Wood and Cabinetry Finishing
Reload this Page >
My wardrobe is perfect except for one detail: An exposed, unfinished edge (pics)
Old 07-22-18, 04:39 PM
I made one big mistake while building my new wardrobe: I made one of the boards face the wrong direction, causing an unfinished section to be exposed. I painted it white to help hide it, but it’s still pretty obvious.
Is there a way I can make the exposed surface match the other, finished surfaces? The wardrobe is made out of particleboard.
Image 1
Image 2
I tried dismantling the wardrobe, but it’s too late; I already nailed the thin backboard in, and I can’t get those 40 or so nails to come out.
Old 07-22-18, 04:43 PM
XSleeper's Avatar
Received 848 Votes on 777 Posts
At this point, Bondo, sanding and paint is about all you can do. Doubt you could get edge banding to match or appear seamless along the edges.
Old 07-22-18, 04:53 PM
Norm201's Avatar
Received 313 Votes on 282 Posts
Look for a molding. Something like a screen molding would look good.
Something like this would work.
https://www.google.com/url?sa=i&rct=...32386315679598
Old 07-22-18, 05:59 PM
XSleeper's Avatar
They also make rubber t moulding if you wanted to cut a slot in it.
Old 07-23-18, 03:47 AM
Received 383 Votes on 339 Posts
I'd use a filler sanded smooth then prime and paint.
Old 07-23-18, 04:06 AM
V
Received 1 Vote on 1 Post
Maybe a narrow strip of Formica ?
Old 07-23-18, 04:31 AM
pugsl's Avatar
Received 75 Votes on 68 Posts
Don't know if will stick to your rough edge but they have iron on edge strips. Use some for laundry room cabinet I built several years ago and most is still on.
https://www.google.com/search?q=iron...hrome&ie=UTF-8
