Removing Brad Nails
Old 10-22-18, 10:54 PM
Removing Brad Nails
So rather than fit my own kitchen cabinets I thought I'd get a professional cabinet maker. He made so many errors I fired him on the first day. Now I'm fixing up the mess and completing it.
One error was nailing on strips of trim to the side of my new maple cabinets.
The trim pieces came off ok but one side has left 4 tiny brad nails stuck through the frame.
What's the best way to remove them without damaging the frame? I thought about cutting them close to the frame, then pulling them through. But they seem pretty stuck. I don't like nails and don't use them unless I have to. Thanks.
Old 10-23-18, 02:56 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
I put a small block of wood under a pair of wire cutters and pull them out. A piece of heavy cardboard would also work under the wire cutters.
Old 10-23-18, 03:50 AM
Received 758 Upvotes on 663 Posts
I agree although I'd use pliers instead of cutters as those type of nails cut easily.
