Hard time sanding maple wood
Old 12-24-18, 12:49 PM
B
I'm making a table top out of ... hardwood flooring (maple).
Anyway, I cut some boards with table saw and it left burn marks on the edge so I'm trying to sand them out with hand held orbital sander. I've been at it for a while and it's hardly taking any of the marks off.
Using 5" disk 80 grit sandpaper (Gator). Should go with even lower grit or try different sander? I'm not used to sanding hardwoods, only pine so far..
Old 12-24-18, 01:12 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
could go down to 60 but maple is like second hardest wood after hickory so just going to have to work at it!
pugsl's Avatar
Received 78 Upvotes on 71 Posts
Take a thin slice with your table saw, less than a 1/2 blade thickness and don't pause on your pass through. Burn marks are a real pain to get off.
Old 12-24-18, 01:51 PM
B
Thanks guys. I had no idea maple is so hard, lol. No wonder even my table saw struggled with it (blew a breaker twice)
Just tried belt sander, and it's getting there!
Old 12-25-18, 04:56 AM
L
Received 10 Upvotes on 10 Posts
Isn't some of it called "hard rock maple"?
Old 12-25-18, 11:34 PM
B
Received 47 Upvotes on 43 Posts
Pick up a new blade for your saw. Carbide and one specific for crosscutting it should reduce or eliminate the burn marks. And as pugsl said, leave a little extra so you can clean it up with a second thin pass. Remember, if you are smoking the wood, something is wrong.
Bud
