Will this wood glue repair hold?
So my sister in law broke one of our kitchen chairs last night, turns out it was because she was scooting on it, and because the leg got pulled outward, it just snapped one of the corner brackets in half.
I thought I may have to find a new piece of wood and drill all the correct holes in it to fix it, but figured I might as well try gluing it first. I know wood glue is strong, but I'm not sure if it will hold in this particular orientation. I glued it overnight last night with a good strong clamp. On one side, the seam is barely even visible, on the other side, you can see easily. But I'm pretty sure it's a good strong bond.
Here you can see where it cracked, going right through one of the screw holes:
Here is the other side, where you can't see the crack as well:
And here is a view of another corner bracket, not broken, so you can see how it is oriented in the chair. I'm just not sure with the screws putting pressure on the block that way if it will hold or not? Seems like about the best way to snap a wood glue joint is to put pressure on it in exactly this way lol:
denidenial22
voted this post useful.
I would've used an epoxy like JB Weld. But if you're careful I think you'll OK. The problem with wood glue is that it will dry out and crack over the years. And if you don't introduce humidity during winter season it will accelerate that drying condition. There are better ways of repair, but what you did is a quick fix and I think is OK.
Ha I should have asked here before repairing it. Ok well thanks. I suppose I'll just not screw it down too tight, and then if it ever does break again I can always just go with the first option and build my own new corner bracket.
Looks like that is a break from tension.
I'd reinforce it with a pair of narrow width hose clamps
Hm not a bad idea thanks. Yeah she is quite heavy and when she tried to scoot the chair, the leg just bent back and put too much stress on that corner bracket.
Actually, get metal truss plates from a hardware store
Get 4 triangle plates if you can, otherwise get 2 squares and cut them into 4 triangles with a hacksaw or tin snips.
That will reinforce the edges and they'll never break again.
